Yes, Horizon.Ah the live one, is your vehicle a MP ?
My MP doesn't have the kitchen.With the kitchen layout, so two rear seats and charging point at the side of the chair. Only checking as I could not get the trickle charge to work. But I only tried the front one and rear one, not the middle one..
Okay so different electric circuit, thanks for the replyMy MP doesn't have the kitchen.
No, you can remove the leisure from the side of the seat. That is how I have technicians do it and I have done it twice the same way. No big deal. A lot easier and faster than removing the seat.To remove the battery you have to remove the front seat, even though on first sight you might think it would come out from the side. He showed me why you would not get it out of the side. The cables are too short and the video they have for the change out is very clear how to change the battery.
Excellent post @enano.No, you can remove the leisure from the side of the seat. That is how I have technicians do it and I have done it twice the same way. No big deal. A lot easier and faster than removing the seat.
In fact, it is easier to do than it is to explain.
1 - pull firmly off the plastic cover to expose the battery:
2 - remove the two screws that hold the battery firmly in place and also support the fuses and the shunt. Remove the plastic venting pipe:
3 - Pull the battery outwards. It is heavy, apply some force. When the negative lead shows out, unscrew the terminal.
4 - Pull off the battery again until you can reach the positive lead, then carefully unscrew the terminal. Rubber gloves and extra care advised. The wrench will come close to the metallic seat base.
5. Fully remove the battery and let it charge for some hours while you appoint a visit to spine care and make a resolution to go to the gym more often.
That is, as far as I know, the proper way to remove the battery(ies). In case of doubt, it is quite clearly stated in the sticker next to the battery (in the above pics, in spanish-from-a-german-translator, just like all the other stickers in the van).
Great post, we had ours changed the other day and it looks like its a HS issue according to the tech at Mercedes, why they take the seat out. But that does not make sense as the seat is much heavier. But Mercedes did try and charge us £840 to replace the battery, until they we reminded them it was under warranty.
But the new battery will now keep the fridge running for nearly 3 days which is a massive improvement over 3 hours…
Yes put the fridge on and see how long it runs for, a good battery will last 3 days. I knackered one lasts about 2 hours. To change the battery is very straight forward, if you have a right hand vehicle, the leisure battery is under the passenger seat. To access it, remove the plastic panel at the base of the seat. Just give it a tug and it pops off.Rather than create a new thread... this seems an appropriate line of chat (if a little aged)...... my spider senses are tingling over my leisure battery health. My MP has only done 7k miles in 3.5 years, 4 of which in the last 2 years, and 2k in the first owners keep.
I am concerned that not getting many miles into the car, the battery will have spent long hours not getting a regular charge. I did drive over 500 miles back from collecting the car from London to Glasgow but other than that its journeys so far have not been any great distances.
Should I swap out the leisure battery as a precaution?
If from the description enough it seems straightforward enough to swap out, has any one done this at all? if so where did you get the battery and how much was it?
What would "normal" performance look like in the battery? If you go to the car say first thing in the morning, what voltage is showing in the charge level display in the head unit? Mine seems to be about 12.2V thereafter when turning the car on the charge will reach 14.2V.
Obviously when the engine is running the full bars in the Charge Status Bar graph are illuminated.
Whats the best way to test whether the leisure battery is holding its charge? Put the fridge on and check the level every 30 mins?
Clearly if the voltage is dropping dramatically then there's an issue?
I have tried to read the manual once again but its not prescriptive enough and once more would welcome anyone's practical guidance from their own experience.
This is a very helpful post that enabled me to easily change leisure battery this week at a fraction of the garage quoted cost. Local MB dealer had battery in stock and it was £220. When I removed the plastic cover at side of the seat there were written instructions on battery removal that matched everything above. Thank you.No, you can remove the leisure from the side of the seat. That is how I have technicians do it and I have done it twice the same way. No big deal. A lot easier and faster than removing the seat.
