Have sussed it out but agree will take a look at what you recommend. You may also be able to help me. Looking around the site some are on inside and some outside, are the outside thermal protectors or to reflect heat or both? What would you recommend we need? Thank youThe front window curtain is a ridiculously stupid solution compared to the VW.
I would bin it and buy a set of Brandrup Isolite which are expensive but excellent.
Thank you will try tonight.I struggled too until I read the manual and following this it is easy.
1. Fold the sun visors down
2. Find the two suction cups on the bottom of the blind and attach these to the two bottom corners of the front screen.
3. Loop the 2 left or right elastic loops over the end of the sunvisor
4. Put the blind around the mirror securing with the velcro
5. Repeat 3 for the other visor
6. Attach suction caps to top of front driver and passenger windows.
Follow this and it takes no more than a minute or 2
Yay it is up thank you so muchI struggled too until I read the manual and following this it is easy.
