MBAC control
Just to confirm as per another thread, no issues with roof functionality via MBAC app on Android, which is seeming like it may be the key.
However, I'm not able to connect to the vehicle at all through the MBAC app without the key in the ignition. This seems to rather defeat the purpose of remote control so I assume this must be a fault. Can anyone confirm please if they experience the same or similar?
hi mate, same for me, I'm wondering if it's the Bluetooth range is too short, once i go back home, the app is frozen, if restart the app, it says lost connection.
Yeah I've had a play. I reckon the range on mine is maybe 3m through 90 degrees ahead. Almost useless.... But not quite! Still means I can put the heater on from indoors!
I guess the main point for me is when you are in the car, using phone to open the roop still much easier and flexible than stick my finger on the car screen all the time.
My car was successfully updated from version 1 to 2, and got an update on the "hermes" module (integrated phone, used for geo location and SOS call), and the gearbox as well (to avoid the jerky downshifts). all seams work very well.
Now i just whish i could disable the passenger front airbag.
Hi Morten1. Where did you get this done? My local dealer is saying there isn’t an update available for the MBAC.
I am located in Denmark, i got it done at Ejnar hessel in Roskilde. When you pair the MBAC app, it clearly states there are two versions and pictures/images/display will differ depending on the version.
Glad you've fixed the downshifts. I've booked mine in locally but couldn't get an appointment for 4 weeks! I'll feel much better if it smooths out as it isn't pleasant and can't be doing wonders for the 'box.
My mbac won’t connect. My phone does find and connect to mbux however. For calls, contacts, media, etc..
First screen states there are 2 mbac version supported and that I can upgrade from version 1 to 2 foc from the dealer.
So I guess I need to book this in.
mbux, mbac, command, multiple versions… Fking shambles Mercedes.
I wrote the above 10 mins ago but posted it anyway even though I worked it out. Hopefully the below will help anyone else struggling?
mbux is connected via the telephone Bluetooth screen. Like any other car you’ve connected to Bluetooth. Easy.
mbac is connected via the advanced control option. You follow the screens in the app and u have to make sure that the ‘visible for all devices‘ box is activated. It will then connect and u enter the last 6 digits of the vin number. Then on the next screen u enter the last 8 digits of the vin number (me neither?) and it all connects. Because I had to enter the end of my vin I assume this means I have version 1. I don’t have the option to raise the roof.
Hi PMP,
Yep like me you are on version 1. as you can't pop up roof on mobile. Let's us know how you get on at dealer when you ask about the updates (software remap) for MBAC please.
Does anyone else’s screen look like this on the section where you are supposed to operate the sound system? I can only change the base and whether I want sound focus in the front or back. So not much use. I mean volume and a play button might be useful!
Hi everyone, jumped on here to ask a question under the MBAC thread hope that's ok?
I have put MBAC on Samsung 9 but note that the facility to pop-up roof option isn't showing. All the others -Aux heating, water, fridge, etc are present on phone. The pop-up roof option is on the MBUX however. The brochure/ads shows people using the smart phone to pop up roof. Mercedes themselves are supposed to be getting back to me but they keep referring to MBAC as Mercedes me?
How are others getting on? Any comments welcome..
Hi, I think the reason pop up roof does not appear on the app is that it is the only one you need to switch the ignition on for. So remote operation is not possible.
